I have a water cooling setup that has evolved over the last few years, but I have gust upgraded to an 8800 GTS with an Alphacool NVXP-G8 and I don't seem to have much flow now.
The rest of the setup is in order of connection is Black Zalman reserator V2 with no pump, Maxijet 1200 pump in it's own tank, 120mm rad with akasa amber fan on the rear of tha case, Swiftech Apogee GT on a Q6600 at 3Ghz, Alphacool mosfet block, Zalman northbridge, and then the Alphacool NVXP-G8.
Quite a heap of bits really
Should I try a batter pump?
Temps are at 80c for the CPU and 62c for the GPU, Both are running at 100% doing folding@home and boinc.
Cpu is clocked to 3Ghz and the 8800 is at 675/900/1782.
Should I try a batter pump?Temps are at 80c for the CPU and 62c for the GPU, Both are running at 100% doing folding@home and boinc.
