Do I need a CPU upgrade?
Try overclocking your cpu before you lay out any money. make sure you have a good cooler and overclock it. I bet many people will tell you the correct ratio and voltages etc. I think you should be ok for a while yet, your cpu isnt that old and a 5770 isnt that fast!
