Do I need a DAC?
28 Sep 2008
Britain
For my HTPC?
I ask, because generally, sound will be passed to an AV receiver through HDMI or optical. But if I wanted to listen to my mp3 collection, I would have to switch outputs on the HTPC.
Is there any real gain in doing this when all I'm using is an AV receiver?
Your AV receiver already has a DAC. If you want to listen to your MP3 collection you shouldn't have to change anything.
For my HTPC?
A £200 DAC like the Caiman or similar wipes the floor with just about any receiver for 2 channel playback.
Even a lot of the cheaper DAC's would put up a great fight against the majority of AV amps.
I have a high end processor but i still used a Caiman for stereo for a few months ....have since moved to a Chord DAC64 but the Caiman is very nice for the money.
you can set the output of most audio programs to a specific soundcard, ie media monkey or winamp, so you can have everything going through the AV except mp3s that go through the DAC :)
Is an uprated DAC necessary for MP3s? If you get one, you should try out MP3s vs. FLACs to see if you'll get the benefit of the better sound.
Unless you have a very good system it's pretty hard to distinguish a well ripped 192-320kbps mp3 and it's lossless counterpart so yes a good DAC is still worth it if you only have mp3.
But a good and revealing DAC is terrible for badly ripped or poorly mastered material....it amplifies all the flaws.
