Probably the wrong place for this, but thought I'd give it a whirl.
In essense I don't really understand the need for these things, but I have heard they can dramatically improve sound quality. My other issue is it seems to me they improve stereo sound quality, but I can't see how this will help in my situation.
My current set up is -
Sources:
SKY HD - optical cable
HTPC using onboard sound card, although I may put in an Asus Xonar DG I have laying about - optical cable
Xbox 360 - optical cable
PS3 - optical cable
and occasionally I will dock my zune directly to the amp - RCA stereo cables
The Amp in question is a Yamaha RX-V 1400. This has no HDMI inputs. Not planning on upgrading this as to get a similar or improved quality sound will cost £1000+, and not worth it for gimicks and HDMI inputs.
As far as I can tell, I either can't get a DAC that would take all those inputs, or it would cost a stupendous amount of money to do so. I also don't think it would help on anything I am using for surround sound, so that would only leave the zune dock, which isn't used too often.
I would however mainly want to improve the sound from the HTPC, which to be honest isn't bad at all anyway, but I can't see how getting a DAC would help? Surely if I'm taking a digital signal from the HTPC, converting it to analog with the DAC, then the amp is converting it back to some sort of surround sound I am just adding a process that will degrade sound quality?
I could be however, and very likely am, getting this totally wrong and need someone to tell me whats what!
Sources:
PS3 - optical cable
