Do I need a flue cap?
  • Thread starter Thread starter uv
  • Start date Start date
uv
uv
16 May 2006
Manchester
Just moved house, and the boiler flue is kinda pointing upwards.. does this need a cap to prevent rain ingress?
Ta!
Is the flue also venting it far enough away? We had a new boiler installed and the plumber had to fit a telescopic flue kit (i think that is the name) as it didn't meet regulation.
When we moved house the first thing we did was service the boiler. The plumber should be able to answer these questions. Our boiler was "£$%ed, it hadn't been serviced in years, old, cheap, no pressure, leaked, cracked and didn't meet regulation.
That doesn't look 300.... Still, take the hande off and it becomes a fixed unit so would pass regs.
Is it a combi boiler? boiler flue's should run upwards away from the boiler.
