- 4 Jun 2020
If I stream from main PC with Nvidia to lounge PC with AMD Radeon via gigabit cables and router, do I still get G sync output to the lounge TV while connected to the Radeon GPU?
No - the receiving end will receive the frame data as an image and then output as per its local setup same as playing a video, etc.
So I need to find a GTX 1050 for the second PC to be able to output G Sync?
I was already planning as such, but the shortages don't help.
Will shop around for a 4K screen that supports both freesync and g sync if such exists.
It is a difficult setup to properly support G-Sync as the frames aren't being generated locally to the receiving end so may be out of sync with G-Sync on the receiving end causing some irregular frame pacing.
Ideally you want a streaming setup that can render a fairly high frame rate either V-Sync or G-Sync into a reasonably high i.e. 100-120Hz or so V-Sync on the TV end.
Variable Sync does not work over remote play at all.
