- 20 Oct 2019
I am using amd radeon rx 5700 mech
What's propping you up? Try that.It holds the gpu up
It holds the gpu up
You may be right - browsed previous posts - post #3 seemed flippant, but is explained away if it's his second second language.I think he might mean a support bracket or similar.
I'm not sure that English is this guys first language, so there's probably a bit of a communications barrier.
