Do I Need a Higher W PSU
24 Jan 2008
Swansea, South Wales. UK
Hi Good Folks...This is a bit LONG winded I'm afraid, but I hope you'll read it and give me good Sound Advice.
I been using a OCZ 80 plus Bronze 650W psu for around 6 years now. Has a 5 year warranty.
It has been running Excellently all this time. (still is). BUT! I now got lots more stuff plugged into my PC than ever before. (It still Works) so far. Here is what I now have inside the tower and Outside. What I have is in my Signature.
Inside-7 SATA peripherals. 4 x HDD + 1 SSD, 1 CD/DVDReader, 1 CD/DVDWriterReader. 1 NVIDIA GTX1050Ti graphics card Low profile.(new) OUTSIDE--I have 4xUSB 2.0 connectors in front (not all used at same time). At rear on tower I have 6 usb 3.0. Also 4 usb 2.0 from PCI-e. I also have a PCIe eSATA. OK, now for the Bewildering bit. lol.
I have 5 usb printers attached, all never switched off, but ONLY one is ever used at once. I have 3x External HDD, of which one gets switched on to transfer things from the main PC. I have had two on at once plus one open from PC. I also have a Enterprise 4x 4 bay External Enclosure run on my eSATA as Photo backups.(only switched on when doing backups) PHEW!!!! I also have a 4 bay Yottamaster External USB with two HDD inside as Backups.(New this week) I did have 4 hdd open yesterday to swap files over. I also got a EASYACC with 4 usb's attached to it. (never used at same time as others. I Also got a 4 Port USB Gigabit Network Server Not attached to PC only to Router with 2 printers attached. Also Plugged in is my Speakers x4 & Subwoofer.
To sum up--PC is switched on at moment with only Internet/Keyboard/mouse being used.
Later I'll open one HDD, plus Lightroom & Photoshop.
Sometime today or in the week I will have the above open plus another HDD. NOT ALL are being used at same time as I would need a 55" Monitor to see all open folders LOL......ANYWAY!
Do I need a bigger PSU of say 800W size of 5.9"(W)x3.4"(H)x6.9"(L). Or is this one OK. Not doing another Self Build or Ready-build until next year maybe. Cost is too high at moment.
I am a Photographer and I do a LOT of photography. I do NOT do Gaming.
MANY THANKS. (Dennis)
1050 Ti has insignificant power draw compared to most graphics card and even half the wattage PSU would be easily enough.
Total power draw during gaming would be closer to 150W than 200W.
And without gaming max power draw will be far closer to 100W.
But most OCZs were average at best and PSU itself might just "rot as designed".
5V standby would be likely the first to go, at least if you've kept PSU powered even when PC isn't.
Hi mickyflinn--If I put in everything correctly it says 500W psu. I'm afraid I don't understand these things. DDR3 memory I had to put in 16GB twice.
Load Wattage=399W------Recommended Upps rating=750va (dont have one)--Recommended psu watage=449W..Again that is if I did it correctly. I put 16 HDD as well lol. Cheers
