Hey All,
I am just getting started in Overclocking my PC.
i5 2500K
GA-Z68xp-UD3p
Noctua D14 Fan
Corsair Dominator 8Gb
I followed an online guide with much the same hardware as i have, and currently got it sitting at 4.5Ghz and its nice and stable.
Idles at around 36c
Load at 68-70c Using Prime 95
Where my concerns lie, is when looking at CPU-Z it shows my Vcore at 1.392v when Speedstep is working and 1.404v when its working at max.
Looking at others overclocks, it would appear my vcore is pretty high. I have brought it down to where it will remain stable. Any lower and BSOD.
other settings are:
CPU PLL Overvoltage - Enabled
Turbo Boost - Disabled
Multi-Steps Load Line - Level 5
CPU Vcore 1.385
QPI/VTT 1.270
CPU PLL 1.810
DRAM Voltage - 1.510
Where my system is stable at 4.5Ghz, should i be concerned by the VCore, or just leave it run as it is?
Many thanks
i5 2500K
GA-Z68xp-UD3p
Noctua D14 Fan
Idles at around 36c
other settings are:
CPU Vcore 1.385
QPI/VTT 1.270
CPU PLL 1.810
Many thanks
