Do I need a USB splitter - if so which is best to get?
25 Mar 2005
Torquay, Devon, UK
Hi
am not sure what my best route is to do this and wonder what others do.
I have a motherboard with just a single usb 2.0 and a single usb 3 on the motherboard; have the nzxt controller plugged into the usb 2 which deals with the lights and the cases' front usb header plugged into the motherboards' 3.0.
I'd like to get an aio but know 99% of them use a motherboard usb header so how do others overcome this problem - Buy a splitter? Buy a splitter box like the nzxt one? Use the usb 3.0 somehow?
I presently use nzxt cam (have h500i case) and also Icue for my Corsair memory and keyboard.
The nzxt splitter box that uses a molex to power it worries me as have heard a few horror stories concerning it.
Would really appreciate some guidance on this one please.
Thanks
Thanks, i've seen a few of these about but wonder how well they work - as they are sharing one port/connection so to speak can you trust these for aio and control boxes together?
I don't have one of them specifically but it's just a USB hub like any other.
Try it and see if your worried about fires then get a pcie card like I sugested.
The link will explain.
The easy solution to the problem is to buy an inexpensive USB hub. The USB standard supports up to 127 devices
https://computer.howstuffworks.com/usb.htm
I'm not so much worried about fires though as say have read some horror stories concerning the nzxt splitter box; i'm more worried that the usb device such as an aio connected to a splitter wont be initiated until Windows starts rather than when pc is powered on. I still often get the Windows 'initiating usb device sound' when Windows starts I believe for my mouse or keyboard.
Don't be worried. I have my keyboard attached to my PC through a hub which is linked to the PC by a 5m cable and I can get into the BIOS.
