It's basically an F5.6 lens.
As you got a small sensor you have more DOF anyway, so F1.8 is like F3.5-F4 from what I'm used to. This is plenty of DOF imo.
Dof will be shallow when you crop the frame tight on the horses head, in which case only the eyes are really the main subject anyway, and all can remain in focus if you take more of a profile shot. This also enables you to be able to get rid of the background.
Secondly, if your framing the whole horse then you have much more DOF as your either further away, or using a wider lens, whichever it is the important thing to remember is the wider the view, the more DOF you have.
Also as your using a smaller sensor, your closer to the hyper-focal point, so DOF should be even less of an issue.
Lastly, if there are times when you don't have enough DOF to encapsulate the whole subject.. so what?
It's an issue of taste, for instance DP is not the biggest bokeh fan and I would say we probably have very differing taste. You see I however am proud to be a complete Bokeh whore. I love the look (of smooth bokeh) much more than seeing every last detail. Sometimes I OD on the bokeh and begin to get tired of it, but that's why I also like to use the wider angle 35mm, it act's as a pallet cleanser, so I'm then free to indulge in as much heavenly bokeh as I like with my 85mm.
Seriously, if this was me, I'd be shooting those horses at F1.4, and throwing caution to the wind like I did with some sheep
here. The DOF you will be getting will be nowhere near as shallow, but AF will still need to be much more accurate than what your currently used to.
