Do I need an adapter???
17 Feb 2013
Rep. of Ireland!
Hi guys, got my rig from OCUK today and relised I might of made a mistake or something. I want to use my rig, connected with HDMI to my LCD t.v. SO far I've not been able to get an image onto the screen from my P.C! Any help here?? Do i need to change setting in the control panel to activate the HDMI slot? DOes only the DVI work as a standard start off???
You are plugging your HDMI cable into the graphics card and not into the motherboard aren't you?
Your graphics card will look similar to:
DO NOT hotlink images. Read the FAQ - Rilot
Your motherboard ports will look similar to:
You need it to be plugged into your graphics card port (thats unless you don't have a graphics card and are using onboard)
