23 Dec 2008 at 16:00 #1 spitzoid spitzoid Permabanned Joined 21 Apr 2008 Posts 872 Location Gloucester, UK I just want to water cool my CPU. Will this be ok? Do I need anymore/less fittings, tubing, etc.
23 Dec 2008 at 16:04 #2 !TIMMY! !TIMMY! Associate Joined 27 Aug 2007 Posts 581 Some fans? Also do you need 8 barbs? Will 6 not do? 2 for cpu block, 2 for rad and 2 for pump top/res. 2m tubing should be fine for a cpu only loop. Apart from that it looks top notch. Last edited: 23 Dec 2008
23 Dec 2008 at 16:14 #3 N19h7m4r3 N19h7m4r3 Soldato Joined 13 Mar 2008 Posts 9,640 Location Ireland That will be great, although grab some compression fittings if you can. They are far better then normal clamps
23 Dec 2008 at 16:22 #4 Bradley8988 Bradley8988 Associate Joined 19 Jan 2008 Posts 2,168 Location Sunny Wales. Yea rads kinda overkill just for a CPU but leaves loads of room to add GPU and mobo into it after.
23 Dec 2008 at 16:24 #5 N19h7m4r3 N19h7m4r3 Soldato Joined 13 Mar 2008 Posts 9,640 Location Ireland Actually even with a quad to themselves OC'd i7's get in the 60's sometimes 70's
23 Dec 2008 at 16:36 #6 Bradley8988 Bradley8988 Associate Joined 19 Jan 2008 Posts 2,168 Location Sunny Wales. They cant fair too well on air then.
23 Dec 2008 at 17:16 #7 moremoney moremoney Associate Joined 16 Dec 2008 Posts 1,643 Location UK Bradley8988 said: They cant fair too well on air then. Click to expand... Just face it, these new chips run really hot.
