Do i need better memory to OC
28 Nov 2002
Which memory is best for my usage?
Im planning on a ds3p board with a c2d E4300. Hopefully clocking to 3ghz+
With this in mind, which of the following memory would be best for my needs.
Corsair 2GB Kit (2x1GB) DDR2 PC2-5400 XMS2 TwinX CL4 £46
GeIL 2GB (2x1GB) PC6400C4 DDR2 Dual Channel Kit £64
Corsair 2GB Kit (2x1GB) DDR2 PC2-6400 XMS2 TwinX CL5 1.9V £65
Crucial Ballistix 2gb Kit (2x1Gb) DDR2 PC2-5300 • 3-3-3-12 2.2V £75
G.Skill 2GB DDR2 PK PC2-6400 (2x1GB) CAS 4-4-4-12 Timings, 1.9-2.1v £75
If you run the 2:1 memory divider then the E4300 will need RAM capable of running 667MHz at 3GHz (CPU@333MHZ) so in theory any PC5300 RAM will suffice.
As your E4300 is highly unlikely to hit more than 380FSB then PC8500 RAM would allow you to run 3.4GHz with the 3:2 memory divider and PC8000 RAM would let you run the 5:4 divider.
PC6400 RAM really gives you no great benefit over PC5300 in this situation so my reommendation would be to buy the Crucial PC5300 kit as it will run the high speed and the tight timings and you get Crucial's 48-hour turnaround RMA service as well if you need it.
In terms value for money, does the Crucial win over the Geil and Corsair?
Corsair 2GB Kit (2x1GB) DDR2 PC2-6400 XMS2 TwinX CL5 £65
GeIL 2GB Kit (2x1GB) DDR2 PC2-6400 CL4 £64
look around forum, loads love it, o/c grt, rma is under 48 hrs i think :)
How does this memory compare against the Crucial Ballistix 5300?
OCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 CL 4-4-4-15 PLATINUM XTC
