Do i need to flash my bios
1 Sep 2010
Bristol, South West
Hi guys i have an asus m4a78 (dont think its the e version or whatver)
Im looking to install an amd 955 quad
My CPU is on the supported list thankfully but ive never flashed a bios before and have heard it can kill a motherboard if done wrong. How hard is the process? could anyone here give me a step by step guide to doing it safely, as i dont have the money to mess it up!:rolleyes:
It looks like i might need to but i might be wrong - in cpu-z the mainboard tab it says version 0601 (ill upload a screenie in a min) and on the asus website it says supported since PCB 1.02G since bios 1206. Am i right in assuming ill need the update?
http://uk.asus.com/product.aspx?P_ID=8DgaI5WgY50udcbZ&templete=2
THANKS IN ADVANCE FOR YOUR HELP:)
will my cpu still run just as well as on a compatible board? This cpu is for someone else.
Also will my cpu still run just as well as on a compatible board? This cpu is for someone else.
hers the pic, let me know if you cant rread it
Latest BIOS is 2301.
Depending on the version of the 955 you have you may need to update the BIOS.
Safest to use Asus EZ Flash to update the BIOS - Don't use the Windows based tool.
See Section 2.1.2 of the user manual for instructions.
Oh ok, so i might get away with it? Hmmm..... Could give it a go i guess
asus EZ flash? But how to i get the file ive downloaded onto the mobo? presumably if i flash the bios, it will need to see a new one to replace it with?
sorry im a noob but i'm presuming a USB drive?
also can anyone recomend a good motherboard for a new build?
Im looking at crossfire boards as in the future may want another 6870, so is it worth looking purely for a x16 and x16 FULL bandwidth on both lanes mobo? Whats the cheapest one of these you guys know.
I see an asus evo mobo for just £70 that has crossfire support, but only x16 in one lane then liuke x4 in the other - hardly even seems worth putting a card in there at that bandqwdth
Man up to you too dog. but x8 x8 is halfing the bandwidth.... seems waste of money but do you say that because those cards will never chuck out more information than a x8 socket could handle?
How much bandwidth of a PCIe 2.0 x16 slot does a high end card use? Let alone a modest GPU like the 6870? Look it up dawg :)
If you read the manual, like I suggested, then it says to put the BIOS on a USB flash drive.
Thanks again for all your help, this one is sorted fo sho. Gonna get me an 8x 8x board if i can find one for around £80 -£100, as i did think thats how the bandwidth thing would work. ive been gettin so many diferent opinions (from another post) my heads in a mess lol
Thanks again, wish me luck with my 1st time flashing:D
