Do I need to mod a NXT phantom case to fit a 2 fan radiator ?
You can fit a 240 rad on the top if you don't have the handle on, looks okay actually, search google for it :D otherwise you can do an internal one with one 120 rad and another 92 although that clearly won't be as good, there is also a build log for that somewhere on google :)
Edit, noticed you said in, no you can't fit a rad in the top bit afaik
You can under it
Inside the top bit you might get away with a single rad but you wont be able to stick a dual in.
Coolers like that are: Corsair H50 H60 H70 soon to release H80 H100. The Corsair H100 will feature dual rad.
What a waste, You'll get better results with a 120mm with a proper fan attached then them big boy fans half sucking air though.
This is true but they are just the stock fans that come with the case. If a exhaust radiator is placed in the case, x2 120mm fans would be more efficient.
Have a look at the build log in my sig :)
You can fit a 360 up there and a 240 in the bottom ;)
