I noticed that my HSF assembly was touching the side of the retention frame, so I released the retention clips and slid the HSF sideways to try and get it in a more central position. I had to slide it a couple of times because when I locked the retention brackets, it still wasn't sitting centrally.
Because I've moved the heatsink a few times, should I need to re-apply the Arctic Silver? I slid the HSF and never took it off my CPU, but I've noticed my idle temp is about 1 to 2 degrees higher, but I'm not sure whether that's down to the temperature of the room.
Cheers, dagwoood.
Cheers, dagwoood.
