Hi all,
just bought a haf 932 case, going to replace my antec 900. question is do i need to remove my cpu cooler to be able to take motherboard out and place it in the new case ??
If so what should i clean the paste off with from the Akasa AK-967 Nero Direct Contact Heatpipe CPU Cooler.
also does the top fan come set up to pull air out or blow air in??
from what i understand it should pull air from front and out at back aswell as top then air from the side panle in is that right?? what is best config for best airflow please all.
Thank you in advance for any help
just remember to be careful and make sure you take care of static and all
