- 19 Aug 2019
Sorry; it wouldn't let me embed it but you can watch the video I made right here
would really appreciate any advice
For me this is part of the building and should be covered by the common building insurance policy rather than you individually.
I think he is the freeholderThis is the only good suggestion, take it up with the freeholder, you are paying them to sort this out.
I'm in London. Can def do some wide shots; hold tight my man.James whereabouts are you based? Can you do a couple of wide still shots of the building to give some context?
The vertical gap doesn't look unusual assuming it's a timber framed building.
You appear to be getting rot at the cill:jamb junction which isn't unusual if it's been poorly detailed, and the answer may be as simple as getting a new cill and good flashing details installed. Depending on the extent of rot, it may need some local patch repairing and scarfing to the worst bits, but drying it out once the continuing ingress has been prevented can be enough to stop it spreading.
How old is the building? I'm also wondering if someone has done a recent render repair? The EML (metal lath) you see is used to give a key to modern renders, but older buildings would not have had EML and would have a lime-based render. If someone has stuck in EML and cement render onto an old lime building it can cause no-end of problems with reduced breathability and actually trap moisture behind the render. It's bad enough on brick buildings but with timber frames... not ideal. Of course if it's a newer building it may never have had lime to begin with. Context will help.
that's rubbish. I had a traumatic childhood and ended up patching over it and bottling it up and tbh it's worked out fantastically. Who wants a fight?There's a reasonable propsect the damage now is the result of someone not trying to solve a problem previously and covering it up. That or just some possibly well-intentioned but ultimately botched repair work previously. It's always better to deal with a problem then cover it up and hope it goes away. It won't.
Didn't we all mate? But let's stay on focus with this one. Therapy is definitely not my expertise and for another area of the forums.that's rubbish. I had a traumatic childhood and ended up patching over it and bottling it up and tbh it's worked out fantastically. Who wants a fight?
I can't help, but that is a brilliant post.that's rubbish. I had a traumatic childhood and ended up patching over it and bottling it up and tbh it's worked out fantastically. Who wants a fight?
I think he's the leaseholder and the freeholder owns the rest including the land which is a common problem place is falling apart and you pay a king's ransom in maintenance and ground rent every year for... lord knows what.
You're not the freeholder - you shouldn't be hacking away at it. The freeholder should be instructing any intrusive work, including investigation. I imagine you are in breach of your lease here.
What is currently there appears to be substandard and defective. It needs properly diagnosing and appropriately repairing. But that is for your freeholder to coordinate. They should appoint a Chartered Surveyor and/or architect to report and recommend further detailed investigations (together with any specialists whose input might be needed).
Don't try and cover this up. If it were me I'd consider emailing them a picture with "a big bit of the wall just fell off in the recent storm! I've done my best to temporarily protect it with some sheeting - hence the plastic and parcel tape, but someone needs to come out and look at this asap. Also the current detail appears to be chipboard and some kind of render which does not seem to be suitable - this needs a proper review and not just a patch repair as the condition of the timber suggests there is a wider underlying problem of moisture ingress rotting the embedded timbers."
Tuck that email away on file and when it comes to acquiring freehold get your own survey and show the surveyor everything you've encountered. It may help give you ammunition when negotiating price of the Freehold since there are demonstrable problems that you will be taking on.
Oh and that vertical gap doesn't look abnormal. The timber on the right is probably structural stud framing. That on the left, window surround or an extra stud timber to receive the window. There may or may not be packing noggins between them at discrete locations, but of all the things going on it seems the least of your concerns at the moment. Gaps like that aren't unusual.
