18 Nov 2023 at 21:45 #1 OnlyAlex OnlyAlex Associate Joined 2 Jul 2021 Posts 256 Location United Kingdom Hi everyone, I have a 4070 and an i7 with 16 GB RAM. I mostly play The Sims 4 and Dreamlight Valley. Do I need to upgrade the RAM? Cheers.
18 Nov 2023 at 22:16 #2 Tetras Tetras Man of Honour Joined 22 Jun 2006 Posts 18,620 If you're not noticing any performance issues, then I guess not.
18 Nov 2023 at 22:34 #3 BUDFORCE BUDFORCE Soldato Joined 3 May 2012 Posts 10,790 Location Wetherspoons Tetras said: If you're not noticing any performance issues, then I guess not. Click to expand... Correct answer. Manly/epeen answer says you need minimum 64gb these days.
19 Nov 2023 at 08:48 #4 OnlyAlex OnlyAlex Associate OP Joined 2 Jul 2021 Posts 256 Location United Kingdom Thanks guys.
23 Nov 2023 at 19:06 #5 PishY PishY Permabanned Joined 8 Sep 2007 Posts 1,094 Location Glenfield, Leicester 16gb is perfectly fine for most things these days
23 Nov 2023 at 19:07 #6 OnlyAlex OnlyAlex Associate OP Joined 2 Jul 2021 Posts 256 Location United Kingdom PishY said: 16gb is perfectly fine for most things these days Click to expand... Thank you.
