- 27 Jul 2006
- Huddersfield
Im toying with the idea of a new build, as i have mentioned before. Though money is tight so if there is a cheaper way to get something better im all for it.
I was thinking the other day about maybe half upgrading the system and then worying about the other half nearer xmas.
Anyway here is what i currently have
Core 2 Duo e6600
Gigabyte GA-965P-DQ6 Motherboard
Ati Radeon HD 3850 512Mb
2 x Corsair CM2X1024-6400 - (so 2gb total)
2 x 250 gb SATA harddrives
Windows xp.
This is all in an antec p100 case with a 600w seasonic (something like that name).
Now my thoughts were to increase the following
OS shift from XP to Windows 7 Home (£100)
this allows me to up my memory to 4 gb, will probly get something along the same lines as what i have in there.
and an upgrade on the graphics card.
Now the OS and the GFX card i would want to move over to the new machine, so a future proof card thats in the just about budget card would be good.
How much of an improvement would i see with doing this on games like Borderlands, Fallout 3 etc. As im not sure where the slowdown comes wether its the ram or the cpu or even the gpu.
Any and all suggestions grately received.
Thanks as allways for your advice.
Zero.
Core 2 Duo e6600
Windows xp.
Zero.
