Hello there
First off I'm going to admit that I'm a bit of a computer novice, I like to think I know enough to understand most stuff but really technical issues I don't have a clue.
So I need some advice please.
I have recently bought a new monitor for my pc, I'm running this graphics card:
Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card
New monitor is the:
Asus PB278Q 27" Professional LED Multimedia Monitor
Is this graphics card going to be good enough to run this monitor on high to max resolution?
(I haven't tried it yet as I'm moving house this weekend and the monitor is still in the box)
If its not can you recommend a good graphics card around the £300-£400 mark?
I have been looking at:
HIS HD 7970 IceQ X² 3072MB GDDR5 PCI-Express Graphics Card
Mostly based on the customer reviews and the award it has on the overclockers site.
One person mentioned this card is pretty big so I'm concerned if it will fit in my case.
I have an Antec 900 case.
The card I use right now fits ok although I doubt there is much room left. Possibly an inch and a half to 2 inches from the drive bays, but there are a lot of cables.
I'm not very good with cable management, I built the pc myself and it is a bit 'straggly' lol.
If its likely I will need a new case could you recommend one?
Power supply I am sure is adequate, its a 750w, although if required I guess I could get a new one :/ lol
Any help would be appreciated
Cheers
New monitor is the:
Cheers
