Do i need to upgrade?
5 Feb 2012
Just wondering if you guys think i should upgrade, with BF4 etc coming. And if so, what parts?
I5 2500k , 4.5ghz
Sapphire 7950 3gb
8gb Ram
Windows 7
128gb crucial ssd
think thats everything !
cheers
I think it depends on what resolution you're gaming at above all else really. If it's 1920 x 1080 I can't see the real gain in upgrading. I suppose you could sell your existing GPU and use the funds towards a faster one, but that's about it really.
There is a performance gain going with haswell, but the hassle and cost against the performance gain isn't really worth it....
If you had Intel 1st gen then upgrading would make sense, but the 2500K is still a very good cpu, especially when overclocked.
