I'm using a Biostar TP67XE that has 2 8 pin sockets but my PSU only has 4+4 connector. The manual says when overclocked I should use both and I have my 2500K at 4Ghz but struggling to get it stable above that.
Execute Disable Bit: Disabled
CPU Core Current Max (Amp): 150
Power Limit 1 Value (Watt): 300
Power Limit 2 Switch: Disabled
Internal PLL Voltage Override: Enabled
CPU C1E: Enabled
CPU Vcore Mode: Offset
CPU Vcore Offset: +0.00v
Phase Control: Full On
CPU VCore LoadLine: Enabled
Turbo Enabled: Core Ratio Limit: 44
I normally turn off all power saving except the thermal throttling and take off turbo mode, I found I was stable easier with only using the main multiplyer.
