Do intel CPUs suffer scheduling issues like X3D?
30 Jan 2005
Inverness
I'm away from home so playing BF6 on my 4080 13980HX laptop
They game plays pretty well getting around 100-130fps but my GPU utilisation is only around 80%
Is this an issue with the E cores?
I'd rather not disable them but just wanted to get peoples thoughts on this before I start messing around with it.
Thanks
Scott
I work shifts when I'm away so won't get back to it until tomorrow I'm just impatient for an answer haha. I will try it when I can though
It's normal for this game to be cpu limited. It's by design, not an issue your end.
I understand it being limited by a higher end GPU at a lower res but I'm essentially playing with a low power desktop 4070 @1600p and the 13980hx has pretty much desktop CPU performance so I thought it should be able to max out the GPU.
Well it turns out my res was 1600x1050 so the GPU was taking it easy. It didn't look half bad at that tbh though. I tried it with the E cores disabled and the GPU stayed above 95% and now with them enabled again it's slightly lower but still better than it was at the low resolution.
I turn off the e-cores on my Dell laptop. It runs much cooler for some bizarre reason. Never known a laptop to get so many bios updates.
I've been running with mine disabled too. I had a perfectly stable -80mv undervolt with them enabled I know from previous messing around that it's not stable with the E cores disabled. I didn't want to mess with it too much so just tried it at -40 and it's been solid so far.
I'm trying to be nice to the CPU as it would be very unfortunate if it succumbed to the intel bug!
The very first time I heard of cpu scheduling issues was due to Intel cpus parking games on the e-cores ..
im coming from a music production background [well more attempted music production really but hey]
and the main thing i heard of was the scheduling software whacking things that needed the better more performant core onto the e cores was a couple of years back i heard
these concerns and im sure its probably a distant memory by now but that was the stuff i heard of, and i assumed at the time that the x3d dual ccd chips that issue would be at least lesser as im assuming
the difference between the two core types/configs is not as vastly different as the e and p core architecture is
i might be totally wrong on that one and obviously im talking about music production so different game entirely but still lol
Thanks
Scott
If it's using eco cores it's probably due to the anti cheat software EA have implemented. Jay2Cents has just done a video on this issue although it was specifically about X3D CPU's but looking at how that software is implemented via a sub kernel level install I can't see why Intel CPU's wouldn't be effected.
Whatever you do don't mess around with your CPU core affinity via your OS, there's a good chance the anti cheat software will think your trying to subvert it and ban your account.
