Do Leadtek GTX cards auto overclock?
6 Jan 2006
Notts/Derby
I have a Leadtek GTX extreme in my system which is clocked at 490Mhz from the factory.
When I ran 3dmark05 I managed to get 8302 (X2 3800, 2gb Gskill, A8n-sli) without any overclocking, but the report said that my GPU was clocked at 529mhz.
Im running the latest offical drivers with no Leadtek software installed.
Is this an error or did the card auto clock itself??
hehe no its not, on the box mine says 490mhz, when im playing or running 3d marks riva tuner says both cards are running at 530 without my doing a thing :) btw im on XFX.
its all gd
As I understand it the 7800 core runs at different speeds in different parts. The geometric domain runs at a higher 529 but the shader & ROP doamin run at the reported 490. So it does not auto overclock. You should see this is Rivatuner monitoring.
OK. So, if I overclocked the card a bit would the geometric domain speed increase? (@ work at the moment so I cant check).
