Do Modern Laptops Have M.2 Slots?
30 Aug 2014
I wanna get a laptop to replace my huge PC and pop the same Win 10 M.2 into it.
Is this possible on the newer slim laptops?
It's a full size M.2 Samsung 970 Pro.
Anything I should look out for in order to not accidentally overwrite it in the process?
I expect it to just boot straight into the Win 10 already installed on the drive at launch.
At the very least, if your laptop has an equivalent M.2 slot that can support your drive, do a backup of all your important data.
Also, if you have a TPM & bitlocker enabled you may need to disable these to minimise trouble.
You have to look at the Spec sheet for the individual Laptop, and make sure to check the length of your Nvme drive is compatible.
Thinking about the ZenBook 14
Also is backing up as simple as connecting the m.2 to my PC, making all hidden files visible and copy pasting the whole content into a backup folder or is there more to it?
Assuming there's no encryption on the drive: yes. BUT, that would (rather inefficiently) only create backups of your personal data, rather than replicate a bootable drive/OS.
There's a hidden partition or two before the data partition that enables the drive to boot and a recovery partition after it. Have a look in Disk Management and you'll see (most of) them. You need cloning software to make a complete bootable copy of the disk.
You might find the laptop will take a maximum of a 2242 M.2 so your 2280 won't fit.
From the Zenbook 14 spec sheet:
Storage
512GB M.2 NVMe™ PCIe® 3.0 SSD
Expansion Slots (includes used)
1x M.2 2280 PCIe 4.0x4
So it's a full sized M.2 it takes.
i've managed to get a windows 10 install to WORK between intel>amd systems but it had some major issues and eventually got flattened for a fresh install.
The ZenBook wouldn't boot the Win10 SSD "inaccessible media" so I just cloned the original Win11 onto it.
Even if I got past the boot apparently it would still have issues with drivers for touch pad etc...
