Molex connectors all come from the PSU.
There is a +12V, +5V and 2 0V lines.
hey, oh no i meant which rail do they draw from?
It depends on which psu you have in mind.
For my one, every 12V output is drawn from a common source, as it is a "single rail" psu. For others you have mixtures, perhaps one line for the cpu, two for graphics cards and one for molex. Since we don't know which psu you have, or what current you want to draw from each line, we can't help you.
What do you mean? Do you just want to run some fans off the psu molex? If so almost any psu will cope with that, and any which won't you really don't want to run a computer with.
The single rail on my one is rated for 64A, so 760W. Many, many fans. This is relatively unusual though, and the single rail vs multiple rail only really matters if you're at risk of drawing obscene currents through one of them. Are you trying to pick a power supply to run a new computer, or one to use for a cooling system but not a computer?
You are aware that no single desktop machine in existence could need 2.5kW of power, and that you cannot simply strap power supplies together if one is insufficient? This is not to say that you can't use multiple supplies simultaneously for one machine, just that doing so is more complicated than soldering the wires together. The two psus will disagree on what "earth" is for one thing.
As stated above, molex cables have a 12V, a 5V and two earth lines. So molex devices could draw from either or both of these. Which molex device do you have in mind?
It would be a really good idea to outline the rest of your plans here, as I have a strong suspicion there will be areas you've overlooked. Your call of course.
The only way I know of to come even close to 2.5kW power draw in a single machine is using peltiers. Based on the subject of this thread I'm confident in saying you're not using peltiers.
What specification do you have in mind?
