do new model stacker cases use the hard disc modules ?
18 Oct 2002
wakefield
as the topic says do the newer stacker models still use the hard disc modules?
i have an older model stacker case and i'm after 2 more of the hard drive modules and they dont seem to be made anymore as i cant see any on overclockers website
wod
No, The CM module is designed for 3.5". With that Kama bay you'll need 5.25" to 3.5" brackets also.
Noticed CM stopped module, luckily bought one ontop of the one included in the case, but should have bought another.
Found "Coolermaster Full Alloy 4 in 3 Devices Module " appears to be replacement, but also found the older type for around £10, from competitor.
Might as well buy one, found a place only £2 del. I think the modules fit 4, but that's with them bunged up together, not enough space to provide airflow. Fits 3 ok.
The are still about if you google coolermaster 4-in-3 module. I managed to pick an extra one up with for my stacker 831 a while back for under 15 quid
The new ones look alright though, think you get an extra filter thing for the front if you havent got one already on your case.
i thought about buying another case but yeah just after a couple of the 4 in 3 modules as they have the fan mounts and to fit another couple of discs in
are the newer modules i've seen the wrong size/shape for older stacker case models ?
