- 2 Feb 2021
I’ve had about 15 EKwb 90 degree fittings over the course of 2 years, my build uses it quite heavily for tight bends.
Over the past 3 months I have noticed the coolant level has been dropping very slowly couple of mms per week, I’ve done a leak check but found no obvious leaks.
Today starting it up in the morning and there was a major leak on one of 90 degrees fittings that bricked the motherboard at the cpu socket.
I replaced the drained the loop and replaced the leaky fittings while in the same time replaced some of the badly bent tubes, after fitting 2 other 90 degree fittings immediately started leaking under high flow test. I immediately checked all other fittings and found 8 of the 15 leaks pretty significantly if you wiggle the fitting slightly, the fittings are also fairly loose with a significant play.
I have yet to test other fittings as I have only EKWB fittings, I was lucky by graphics card has not been affected. Please remove these fittings from your PC, or at least do a wiggle test on the fittings regularly.
RIP ASUS Crosshair MB
Before
After (leak testing)
My fittings
Before
My fittings
