I'm stress-testing my 6600 at the moment - to see how far I could go for a 24/7 setup.
I was just a bit concerned as temps in TAT had drifted up to 64C TAT under load at 1.525V Vcore (bios)
but after 30 mins of Orthos - I opened up the case - touched both the Freezer 7 Pro heatsink and the heatpipes and they are not even warm to the touch.
this compares to my P4 that was overclocked and was at 65C (case temp though) and when I did the same test - I actually burnt 3 stripes onto my finger !
so either these chips are far more sensitive to temperature or we just worry bout the temps too much ?
I have a 965 chipset if that makes a difference.
that said - the RAM - Ballistix 8500 running at only 960 MHz 4-4-4-10 @ 2.25V (stock) are HOT - you can only just about leave your finger on them ..
cheers, Mark.
cheers, Mark.
