2nd time in 6 years I've had some damage to my car due to these type of vehicles
1st time - truck on motorway with some sort of gravel load - may have been larger than gravel - but had a "drain" for water at back (presumably as open top) - but the drained water contained lots of small stones .... I thought it was hailing (bright summers day) - I was being pinged by small stones from about 1/2 a mile away fromthis truck - when I finally realised what was happening - the damage was done - polkerdotted bonnet (black car - so any chip shows up)_ and a windscreen pettered with tiny dents/damage - wasn't too bad unless it hit the sun then looked like windscreen was covered in rain dots. I had to get the windscreen replaced in the end. Couldn't get near enough to get an ID on the lorry as didn't want to get further damage. Bonnet was forver polker-dotted - and annoyed me as I'd only had the car (admittadly 2nd hand) - about a month. The stone chips are still there - but its a dual-tone black (Pirates Black) - so touching up doesn't help.
2nd time - last week - was following (not close) a local (I know the company this time but won't say on here) "materials" hauler - seemed to be carrying something heavier than sand - maybe some light gravel. Was open at the top - although did have a cover that could pull across - but it wasn't pulled across !! All was fine until he went over a bump - and although I couldn't see anything come off the back of the lorry I did hear what sounded again like hail hitting the windscreen etc - and sure enough my windscreen has lots of tiny stone chips .. grrr - not bad enough to need replacing this time - but very annoying none the less when its not your fault.
Problem is you have no proof so you can't really take it further with these companies -b ut its very annoying. Anyone else had this ?
How would they feel if it was the other way round ??! - with the latter I feel like reporting the company to the police (should they have the covers installed? laziness) - but I probably won't as it won't be of any use - and will just waste my time.
cheers, Buckster
cheers, Buckster
