Do the systems usually come with wireless cards?
2 Jun 2013
So I'm looking into getting a computer, but I was just wondering if the systems (Looking mainly in the Gaming Systems bit at the moment) usually come with wireless cards installed?
My mate bought a computer from overclockers before, and whilst it's amazing and he loves it, he couldn't come online for about 1 week while he secured a dongle.
Unless they state that they do, it would be wise to assume that they don't come with wireless cards unless the motherboard has that built in functionality, which is easy enough to check with a quick google.
Why not just order a wireless dongle with the system?
Cheers for the info, will grab a dongle when I make the order.
I have recently seen some motherboards having the added adapter with them. A dongle would be the way to go. Though i am curious of what swiftmetal posted, How does it work exactly?
Some systems come with WIFI and others don't. It tends to say so in the specification section of the description if it does.
Most gaming systems don't because WIFI is far from ideal for online gaming and those who do want to game via WIFI tend to invest in the higher end of the tech range.
I'll vouch for powerline as an excellent alternative. I've tried it in three homes (including a flat with some seriously dodgy wiring) and never had more than a couple of percent loss in bandwidth. Much, much better than WIFI.
I'd recommend powerline adapters over wireless but have found if you have any type of fiber connection they can cap your speeds.
On the subject of power-line adapters, can these be mixed together say 4 in the house? Do you get much slow down due to collection detection when multiple power-line adapters are in use?
