Hi there, the other day I posted about my crappy Crysis framerates, but I'm over that now
Basically, one of the problems I thought it was, was the extremely high idle temp of my 4870x2 (83 degrees).
Anyway, people said thats normal, but being extremely worried about my hardware, I decided to up the fans to 45% using Rivatemp.
Now I'm getting temperatures of 32 degrees idle, and 42-5 degrees when playing crysis, according to CCC and GPU-Z. Is this right, or is something wrong with my temperature sensors
In terms of cooling, I'm using the Antec 900, with the 3 Case fans on high, and as I said before, the GPU fan is on 45%.
Basically, one of the problems I thought it was, was the extremely high idle temp of my 4870x2 (83 degrees). Anyway, people said thats normal, but being extremely worried about my hardware, I decided to up the fans to 45% using Rivatemp.
. BTW TheRealDeal, what exactly do you mean by 'artifacts' (I'm still learning about this stuff
