Do these exist?
20 May 2006
Is it possible to get a rad for a watercooling system that fits into were CD drives go, 5 1/2 " ? With a built-in fan?
I'm sure I seen one somewere but I cant seem to find any now.
Chaz!
NachT
If I could get one that wasn't made by thermaltake would it be any good?
The thing is, I don't have a lot of room in my case. And it would help if I could keep this water a bit cooler than it is, arg lack of space! :rolleyes:
Probably be better, but due to the restricted intake and limited space I doubt it would match a normal 120mm rad.
coolermaster make some but they arent much good, they will barely keep your temps below that of a decent air cooler and the fan inside it has to work so hard its louder than an air cooler as well
so essentially its water cooling without the two main benefits of water cooling :p
if you are really going to get a water kit get a proper one, faffing around with cheapo all in one solutions wont help IMO
