Do these exist?
Status
Not open for further replies.
Due to recent rules its a tough one to answer directly...
Certain imported monitors will 'overclock' to around about 120Hz, though they aren't commercially available.
I'm guessing a lot of people are a little wary of posting on this thread now.
In any case, apart from the ones you already know about:
Nope, there shouldn't be any.
(and I know you know what I mean, as you have already participated in the discussion)
I'd advice to choose whichever is the more important feature (2560x1440 vs 120Hz), and go with that only.
Maybe HP ZR2740W would hit the bill?
- 27"
- 2560x1440
- 60Hz
- IPS
- pivot
- standard gamut
- PWM-free
- low input lag
- semi-glossy screen surface (or light matte, or whatever it's called)
There's also the Dell U2713HM, with pretty much identical features. But it has gotten some flack for reduced backlight bleed standards (and warranty), so consider yourself warned.
I think the 30" ones are wide gamut and considerably more expensive, so not gonna recommend those.
Also, @pgi947:
Like I said above, he should already know about them, as he has at least already posted on the particular mod thread.
And as it's still a fairly new moderation rule, I feel safe to add this for others:
http://forums.overclockers.co.uk/showthread.php?t=18521433
(just in case someone missed the memo, so they can read it now, so they won't get future warnings from mods)
Status
