Do these settings look ok?
mrk
mrk
Man of Honour
18 Oct 2002
Uranus hehehe
Hey guys, just trying to get the best out of this setup getting ready for upcoming games and have tweaked a few settings:
Just wondering if that all looks ok? I saw in CPU-Z the memory speed is reported at 445MHz instead of 500/499 could this be because of the strap setting to 400mhz?
My CPU does not like running at 400fsb either with a 9x multi but temps at 333x9 are 28 idle 40~ load.
Ram is 2x2GB GSkil DDR2 1000MHz 5-5-5-15 kit.
The vcore droop maybe quite high though? I noticed when in use the vcor drops to 1.28 and idle it's 1.31 so should I up the vcore to 1.625 so vdroop is compensated ?
Cheers!
It's fine the way it is but you could tweak the following:
up the PCI freq to 110 (small gain)
Tighten the ram timings Cas 4 if possible. 4-4-4-12 maybe?
Enable Transaction booster and set to 1.
Up the CPU voltage only if the CPU is unstable
You are correct about the strap :)
Ah many thanks! I set the fsb strap to auto and my ram is now a healthy 1ghz (2:3 divider)
I can't adjust the timings to be any tighter though as my mobo doesn't like high ram freq + tight timings unfortunately with a overclocked cpu!
I think this may well be my sweet spot :)
If I get any crashes I'll up the vcore a bit of course.
Also best t leave nb voltage on auto?
