Do these speeds look right?
11 Oct 2009
Greater London
Moved to BT on Monday, after a few days the speed seems to be sticking at 1mb odd. Do these router stats look fine?
Code:
ADSL Line Status
Connection Information
Line state:	Connected
Connection time:	0 days, 00:43:13
Downstream:	1.125 Mbps
Upstream:	875.5 Kbps
ADSL Settings
VPI/VCI:	0/38
Type:	PPPoA
Modulation:	G.992.3 Annex A
Latency type:	Interleaved
Noise margin (Down/Up):	10.7 dB / 6.8 dB
Line attenuation (Down/Up):	46.4 dB / 28.5 dB
Output power (Down/Up):	15.8 dBm / 12.6 dBm
FEC Events (Down/Up):	278962 / 8816
CRC Events (Down/Up):	341 / 376
Loss of Framing (Local/Remote):	0 / 0
Loss of Signal (Local/Remote):	0 / 0
Loss of Power (Local/Remote):	0 / 0
HEC Events (Down/Up):	1009 / 2071
Error Seconds (Local/Remote):	109 / 79
5.5, but been with o2 the past few years which stuck at around 2.7mb. We moved to BT when the speeds oddly dropped to under 1mb and kept losing connection every hour or so, and neither o2 or BT could find the fault. Well, at least the connection is stable now, just slow...
Yup, it's in the master socket, tried test socket too. Basically tried everything o2 and BT recommened too such as removing possible intereference. Just noticed it's running at G.992.3 and not G.992.5... Looks like I have to give BT a call :p.
