Do these temps look about right?
22 May 2006
I'm running my 2500k at stock turbo speed of 3700MHz at 1.2 vcore, it's fitted with a Corsair H60 water cooler and IC carat 24 TIM. At the moment the side is off the case to provide maximum air flow. After running prime95 for 15 min the temps accross the cores have reached 57c - 60c. The cooler has 2 apache black fans in push pull running at 1100 rpm and the pump is running at 4400 rpm. These temps seem to be on the high side.
They seem ok, better than mine. I'm using a Hyper 212 plus and my i5-2500 (4.2oc) load temp under prime95 (30mins) was 76, fan speed 1900rpm, voltage 1.272.
Yours seem ok, I would be happy with 60. Try googling for people with the same water cooler and see what their temps are.
