It's a proven fact that timings are better than clock speed. Think of it like graphics pipelines. The more you have, the lower clock speed you can have and it'll still perform better or same at worst. Think of timings like pipelines, except it's not more you need, it's lower values that you need.
I've noticed that my 2-3-3-5-1T at 195mhz (234mhz with a 166 divider) outperforms it at 2.5-3-3-5-1T at 234mhz (234mhz with a 200 divider). Not only in 3DMark, but also in games, they're smoother.
If you want to get the best though, you should set your CPU multi lower, set your RAM divider to 166, and then up your clock speed, so you end up with a "perfect" CPU and RAM speed combo.
Of course, the divider should be higher for DDR2, but for DDR, the best divider is 166, that's what i've found anyway.
So in summary, timings are a lot more important than clock speed.
Also, how the **** did you get better timings on cheap samsung DDR2, than i can get on my Corsair DDR! Insane but well done! I wanted to go for 2-2-2-5-1T, but my rig won't even POST then.
I'm selling this Corsair anyway, and getting 2GB of Geil. Apparently it outperforms the Corsair i have, even though it's a value kit!
