do while loop
1 Dec 2004
S.Wales
Code:
do { pass = 1; pass<=arraysize-1; pass++;
    while (swap == false);
I need abit of help with some c++, how would i say do the following while swap == false?
it needs to sort through an array of data whilst swap is equal to false, once everything is swapped bool swap will change to true and the programme will exit..
I have the rest of the code i just not sure what to put in this first do while loop.
If you're just looking to sort a load of data (i'm guessing here, from looking at what you've posted), why not just use the standard sort algorithms?
The loops uses a boolean condition so you don't need while (swap == false), you can use while (!swap) instead.
Thats the way iv been shown how to do it im afaid, here is my code
Code:
#include <iostream.h>
#include <cstring.h>
void main()
//Variable declarations
int item[10];
int pass;
int comparison;
int temp;
int arraysize;
int i;
bool swap;
//input
item[0] = 2;
item[1] = 1;
item[2] = 3;
item[3] = 4;
item[4] = 7;
item[5] = 5;
item[6] = 9;
item[7] = 6;
item[8] = 8;
item[9] = 10;
arraysize = 10;
//sorting
pass = 1;
do {
	for (comparison=1; comparison <= arraysize-1; comparison++)
        	if (item[comparison-1] > item[comparison])
         swap = true;
         temp = item[comparison-1];
         item[comparison-1] = item[comparison];
         item[comparison] = temp;
    pass++;
    while ((swap == false) && (pass<=arraysize-1));
//output
cout<<""<<endl;
cout<<""<<endl;
cout<<"State of array after sorting: "<<endl;
for (i = 0;  i<10; i++)
cout<<item[i]<<endl;
Im trying to find a place for that pass++, am i correct in saying that it goes somewhere before the while loop, because i only want to increment further if swap == true, if there are no swaps (swap== false) then there is no-need to increment any further and the loop will finish.
I want to try to keep with the structure im working with, any one telling me i shouldnt do this, replace this with this as it will only confuse me more.
if and while just evaluate the contents of the parentheses and see if they're true, so it's usually just as readable and much easier to negate the variable with !:
Code:
// in C++...
if(foo == false)
if(foo == 0)
if(!foo)
// ...are equivalent
Code:
// in C++...
if(foo == false)
if(foo == 0)
if(!foo)
I dont get what you mean?
You mean replacing (statement == false) with (!statement)
Yes he is just saying they are the same. Just use the method you have been taught (foo == false) it its more natural/readable for you. The other way (!foo) is just a bit shorter. Dont use (foo==0) . . its a bit confusing.
Essentially, to get the code working you're going to need to change:
Code:
    pass++;
//output
to
Code:
        pass++;
   } while ( (swap == false) && (pass<=arraysize-1) );
However, instead of "while ((swap == false) && (pass<=arraysize-1));", you could also write
"while ( !swap && (pass<=arraysize-1) );" - both do exactly the same.
Btw, what are you using to compile this? as I had to change the top of the file to:
Code:
#include <iostream>
#include <stdlib.h>
using namespace std;
int main()
to get it to compile.
Code:
    pass++;
//output
to
Code:
        pass++;
Code:
#include <iostream>
#include <stdlib.h>
int main()
Thanks a lot mate, that makes more sence to me..Ill probably do it one way then add the alternative as a comment
Well we use a version of Borland C++ 5.02 i think, but i use bloodshed dev C++ at home
Why aint in compiling in bloodshed dev C++??
its complaning about the bits of code like cout<<""<<endl; which worked fine on borlands version of C++..
I have created a new project and put the code in
here is my code
Code:
#include <cstdlib>
#include <iostream>
#include <cstring>
#include <istream>
int main(int argc, char *argv[])
int item[10];
int pass;
int comparison;
int temp;
int arraysize;
int i;
bool swap;
//input
item[0] = 2;
item[1] = 1;
item[2] = 16;
item[3] = 4;
item[4] = 7;
item[5] = 5;
item[6] = 9;
item[7] = 6;
item[8] = 8;
item[9] = 15;
arraysize = 10;
//sorting
pass = 1;
do {
         swap = true;
    pass++;
//output
cout<<" "<<endl;
cout<<item[i];<<endl;
    system("PAUSE");
    return EXIT_SUCCESS;
The error is not the cout line, but above it.
You need to remove the '{' just above '//output', and the one just above 'system("PAUSE");'. You also need to take the ';' out of 'cout<<item;<<endl'.
Iv noticed tho it does not sort my array items correctly
Code:
#include <iostream>
#include <stdlib.h>
int main()
int item[10];
int pass;
int comparison;
int temp;
int arraysize;
int i;
bool swap;
//input
item[0] = 2;
item[1] = 1;
item[2] = 16;
item[3] = 4;
item[4] = 7;
item[5] = 5;
item[6] = 9;
item[7] = 6;
item[8] = 8;
item[9] = 15;
arraysize = 10;
//sorting
pass = 1;
do {
         swap = true;
    pass++;
//output
cout<<""<<endl;
 system("PAUSE");
Code:
#include <iostream>
#include <cstdlib>
#include <algorithm>
int main()
int item[10];
//input
item[0] = 2;
item[1] = 1;
item[2] = 16;
item[3] = 4;
item[4] = 7;
item[5] = 5;
item[6] = 9;
item[7] = 6;
item[8] = 8;
item[9] = 15;
int arraysize = 10;
//sorting
std::sort(item, item+arraysize) ;
//output
cout<<""<<endl;
for (int i = 0;  i<arraysize; i++)
 system("PAUSE");
I take it you're trying to implement bubble sort yourself. In that case your loop logic should be "keep repeating doing a pass while a swapped in the last pass", not while "not swapped" as you had it. When you've done a pass without swapping, then you're done (since all pairs of elements are in the correct order.)
Fixed code:
Code:
#include <iostream>
#include <stdlib.h>
int main()
	int item[10];
	int pass;
	int comparison;
	int temp;
	int arraysize;
	int i;
	bool swap;
	//input
	item[0] = 2;
	item[1] = 1;
	item[2] = 16;
	item[3] = 4;
	item[4] = 7;
	item[5] = 5;
	item[6] = 9;
	item[7] = 6;
	item[8] = 8;
	item[9] = 15;
	arraysize = 10;
	//sorting
	pass = 1;
	do {
		// start the pass remembering that we've not swapped yet:
		swap = false;
		// loop over the array, if we swap, set swapped to true
				swap = true;
		// incremement the pass count at the end of the pass
		pass++;
		// if we've swapped, then we must do another pass (since there might
		// still be unsorted entries.  (If swap == false we're done.)
	} while ( (swap == true) && (pass<=arraysize-1) );
	//output
	cout<<""<<endl;
	system("PAUSE");
HTH
