Do you bother with a separate admin acc for single user pc?
13 Mar 2003
location,location
I am talking about a home pc only used by myself. I am considering whether it is worth setting up a separate admin local account with administrator rights and then having my day to day outlook account as a standard, non-admin account.
Would it really offer extra security over running one acc as admin and relying on UAC?
Some will say yes, some will say no. Both have their reasons, there is no right or wrong.
I have one account only, always have and always will. Never had anything be compromised. It works for me!
Set up Admin account on the parent's laptop.
They use a standard, locked down one.
Can't trust parents these days!
I give myself read-only access to most of my NAS. On the off-chance that I get one of those dreaded crypto viruses.
No, only on work pc's.
At home UAC and all the security crud can go **** itself.
UAC disabled, and always enable the hidden/disabled ''administrator'' account, and promptly use that for everything.
On work lappy I do use a passworded Admin account ( not a regular user, that'd drive me mad with all the UAC/runasadmin enter pw prompts) and have UAC on a medium-low level, but also only because I ''have to'', personally I hope all the unnecessary prompts burn in hell, viruses and malware gets on anyhow with a user that doesn't use common sense with executables, regardless of these security ''measures''.
Having a standard user account is best practice because the user has to enter a password before privilege elevation can take place, similar to the sudo command on Linux. A regular Windows account has standard user privileges until UAC elevation occurs.
Be a member of the administrators group and keep UAC enabled if you want convenience, or use a standard user account if you want better protection.
Thanks for the replies. I have been a linux user for years so I an used to separate admin accounts or using sudo for admin tasks.
At the moment I am leaning towards just having one acc as my usage is pretty low risk but I may try the separate admin account and just turn the main account into admin if the separate account becomes too annoying.
No more annoying than Linux & OSX.
