Do you get small optical drives?
11 Oct 2005
Hi,
I am building a new PC with a Phanteks Enthoo Pro case and an NZXT Kraken X61 cooler. I have installed the radiator unit, but have just discovered that there isn't quite enough space in the top of the case and I cannot get my Blu-Ray drive all the way in before it hits the radiator. There basically isn't another configuration I can use with the bits I have (there is only one optical drive bay).
Currently it looks as if I'll have to have the optical drive protruding 2cm out of the case. This isn't the end of the world but it does rather spoil the look of the thing! Are all optical drives a standard size or can you get smaller ones?
