Do you have problems with belts?
18 Oct 2002
London, WC1
I have 3 belts that I wear frequently. I find that the holes in the belts are just NOT in the right places. E.g. take my black one. For one pair of trousers I use one hole, for another, another hole, for another, I had to drill a hole in between two existing ones, and for ANOTHER pair, I might need to drill a hole in between an existing one, and an already-drilled one.
This really winds me up and I just think that someone should invent a sliding business belt so one isn't confined to holes!!
/rant
i prefer the belts that have no holes. though you cant generally wear them with trousers :/
my belts *are* the correct size for me - but the holes aren't frequent enough. I need a higher density of holes / inch.
currently: o o o o o
need: oooooooo
since I find that I need holes at these positions: o |o||o o
reason: different fit trousers require different hole placements
Why don't you buy a belt that is the correct size for you?
Eh?
Its not that the belt is too big or small, its the placement of the holes. everybodies size fluctuates daily, but not as much as 1.5-2". Need more holes. thats all.
need: oooooooo
Which is why you get a belt which matches the specific pair of trousers.
Do people only have one belt?
No that would be silly :p.
I buy a belt that matches the trousers, as long as it fits. I consider fitting to mean that the holes are correctly lined up as well.
I don't really understand the problem. Belts should be primarly for decoration, so just use the hole that is just looser than exactly where you want it.
What?
I have a similar problem when wearing one of my suits, however with another the waist of the trousers is thicker so fits my belt perfectly.
You're looking at this the wrong way. Simply eat enough crisps or Pringles to regulate your girth to achieve the optimum gut to belt hole index.
I would gladly wear braces, but my suits don't have braces backs and I'm not emo/w/e enough to wear them with jeans.
