- 28 Jul 2007
the lack of a status bar in the vista defrag utility.
It would just be nice to see how much progress it has actually made, especially when it takes hours and hours as Stonedofmoo mentioned.
Anyway im gonna give perfect disk a try.
Get PerfectDisk 2008.
Ah okay, what are your system specs?
I defrag once a week, normally scheduling it over night but i thought I would manually do it this time before I install service pack 1. And its slllowwwwwwwwwwwwwwwwwww
Its 'slow' by design as its mean't to run in the background in the lowest priority so that it doesn't interupt your use of the computer.
O&O Defrag 10 Pro.
If you're talking about the Vista defrag program thats not true, if you look in device manager and processes you can see it runs at normal priority. In fact you can raise it to high priority and it's still slow.
