Do you repair tires?
9 Dec 2009
Bristol
Has anyone seen sticky string being used as a temporary repair?
I watched it being done on a friend's car and was so impressed I'm considering putting together a little kit for the boot as an alternative to the can of Tyreweld which I have instead of a spare tyre.
OP
17 Jun 2012
That's what I'm planning trying, you ram the sticky rubber strip into the hole.
1 Jun 2013
How do the pros do it?
Well for a start there are quite a few limitations on where the puncture can be if it is to be repaired (how close to the shoulder, not in the wall, where on the tread, etc), and you're not allowed to have two repairs in the same quarter of the tyre. The tyre is removed, the hole is filled, and the inside is patched before the tyre is put back on the wheel. So instead of a bit of sticky string pushed through from the outside, a plug with a patch is glued from inside the tyre.
The pressure keeps the glued patch in place, the plug is part of the patch, so the plug can't come out of the tyre. It's rated for the same speed as the tyre and is expected to last as long as the tyre does. That's quite different from a string repair.
When I had one done last year, I think it cost me about £20 on a £100 tyre (those are London prices), they were busy when I dropped it off without an appointment, and I picked it up a few hours later. If they were not able to repair, they would have put on a replacement tyre instead.
Really, it's such a small amount of money over buying a string repair kit, I'd rather have a much better and safer job done by someone taking the tyre off and doing a proper patch/plug. Don't skimp on your tyres, especially with winter coming up. They are the only thing holding you on the road.
18 Oct 2019
U.K.
If it is a proper patch and not in a dangerous region of the tyre there is absolute no good reason not to have it repaired, it would be just wasteful to replace the tyre IMO.
I got a nail in a brand new tyre, plugged it, ran it for a couple of years and when I took them off at about 1.8mm of tread left, the patch was still perfect.
I wouldn't trust the string plug, although they may work in a pinch as a get-you-home.
OP
17 Jun 2012
Well there's a kit on the bay for £3.25 so can't hurt to have a go. I know, that's cheap, but it seems to have all the pieces.
28 Sep 2012
Monterrey, Mexico
Do you have a driveway made of upturned nails or something?
Do about 30k miles per year across two different cars, mostly in industrial areas in Mexico. That total isn’t even counting the tyres I’ve had to replace completely due to pothole damage / nails in the sidewall etc.
More likely bullet holes being repaired than nails in mexico ;)
Knowing Mexican tyre shops, they’d be perfectly happy to “safely” repair bullet damage :p
18 Oct 2002
Sandwich, Kent
I've repaired a couple with those sticky rubber strips you poke through / add glue to and trim.
They take a hell of a lot of force to get into the hole, and then they're glued on top of that. I can't see how you'd ever get a rapid deflation from using one. Only problem I've had is you can tell the tyre is a little unbalanced - not enough to worry about though.
My wife gets loads of nails in tyres. She works for the council and I swear some oik thinks it's funny to throw nails and screws all over their car park.
Caporegime
21 Jun 2006
I've plugged motorcycle tires, car tires, truck tires, then used them until they wear out. People are iffy on motorcycle tires but I've shredded them on corners and done 175mph and they are always fine.
Plug it and forget it.
175 mph on a motorbike?
What's the survival rate should you hit a pot hole and go off?
