do you think i have a faulty card?
11 Jun 2006
Middlesborough
this is my system, im running xp home with all the updates and nothign is overclocked
AMD Athlon™ 64 FX-57 Processor
NVIDIA GeForce 8800GT 512MB
SB Audigy 2 ZS Audio
OCZ 2GB (2 x 1GB) PC3200 Dual Channel Platinum Series
ASUS A8N-SLI Premium
Thermaltake Purepower 560W Psu
120gig Maxtor SATA
300gig Maxtor SATA
since i replaced my old 7800gtx with the Leadtek 8800gtb i have been having problems with oblivion, it just seems to randomly freeze and the only way to exit is by ctrl,alt & delete
i tried the game with and without patches & mods, i also tried the new beta drivers and the drivers on the leadtek site but nothing seems to help
when the game crashes the graphics seem to get corrupted shortly after, i managed to get a screenshot of how it looks after a crash by running it in a window
the thing that im confused about is how i can run unreal tournament 3 perfectly without any problems but this game crashes each time i play :confused:
my temps are around 54c when it happens so i dont think its a heat problem
right now im using ForceWare 169.21 but i tried 169.28 beta & it did the same thing :confused: i also tried the 11.1 drivers from the Leadtek site
the game runs perfectly but then it seems to suddenly crash, its never in a specific place or during a load screen
its happening with titan quest too so it looks like its going to have to go back, does anyone know the procedure to rma something? i have never had to do this before
i just solved the problem, i used ntune and underclocked the card from 680 to 600 & now its not crashing anymore :rolleyes: ill have to give ocuk a call tomorrow about sending it back :(
