2 Feb 2006 at 15:48 #1 0gami 0gami Associate Joined 19 Dec 2005 Posts 676 Location Manchester, England What do you use for character movement?
2 Feb 2006 at 15:51 #2 Thesnipergecko Thesnipergecko Soldato Joined 17 Oct 2002 Posts 7,484 Location Stoke-on-Trent Both, depends how complex the move it a half moon is required i use the analogue, but if i need to double tap a direction its d-pad. If i need to do a half moon and double tap i direction i use my feet too! Paul ...
2 Feb 2006 at 15:52 #3 Wyrdo Wyrdo Soldato Joined 19 Feb 2004 Posts 15,102 Location Darlington, UK I've been using the analogue stick so far but I haven't really played this much yet.
2 Feb 2006 at 15:56 #4 NokkonWud NokkonWud Caporegime Joined 1 Oct 2004 Posts 26,315 Location Redcar Analogue.
2 Feb 2006 at 16:17 #5 Smit Smit Soldato Joined 6 Mar 2003 Posts 6,230 Location West Lothian Analogue unless I'm in Sparring mode and finding it hard to pull off a move and then I'll give it a try with the D-Pad
2 Feb 2006 at 16:27 #6 Pac3y Pac3y Associate Joined 24 Mar 2003 Posts 1,890 Location Rotherham I use the D-pad mostly. I find it allot easier to counter with it.
2 Feb 2006 at 16:30 #7 IceBus IceBus Soldato Joined 18 Oct 2002 Posts 9,817 Location , Washington DC D-Pad for accuracy.
