Dock for iphone
23 Jan 2005
Hi looking for a wireless dock for my 15 pro max that can sit the phone in landscape and only for the iPhone not any other apple stuff. Any ideas it’s to sit on my bedside unit just displaying the time ?
thanks i was looking at that but worried that when removing the phone it would pull the mount off the table top
It doesn’t. I have the previous gen which has an AirPods charger under it. Doesn’t move at all.
You kind of grab it at the bottom and pull up and it disconnects the magnet if you will. It’s just automatic you aren’t even aware that you do it.
It’s solid though, won’t fall off at all.
I have the nomad one, had it over a year, it is pricy but looks good and it is heavy so when you lift the phone off it doesn't move.
I got it in white and wish I got the black one though, because the magnetic part of it attracts I guess ferrous dust and it is hard to clean.
Edit: this one: https://nomadgoods.com/uk/products/stand-one-silver
Now that looks nice and I would be looking at black ones anyway, will have a better look at home
Thanks
