Hey, i just got my water cooling loop up and running, and im running sum benchmarks on my overclocked GPU, but my CPU sensor is saying that my CPU is running 5 degrees cooler than my water temp, im using the sensors in easytune just wondering if you guys have come across this?
My GPU temp under load is about 36 degrees in Heaven bench, that pushes the water temp up to 27 degrees, and the cpu was between 21 and 22 degrees. Either my i have a magic CPU thats helping to cool my loop
, or i need to look for better sensor software?
Cheers.
, or i need to look for better sensor software?Cheers.
